So I had been using this to keep me from switching to PIO, and it worked great: http://neodon.blogspot.com/2006/07/little-...hard-drive.html
Then I had a nasty power surge and had to get a new MoBo, do a clean install of XP, etc. Generally things have been okay, but I can't find the indicated registry keys...are there alternate ones I should be aware of?
Thanks!
I don't understand - why are you switching to PIO at all?
If the HD is installed correctly, your IDE or SATA controller will automatically set the transfer mode.
More info, please
Read the link - there's a flaw in XP that will default drives to PIO at certain times. It has nothing to do w/ how the HDs are installed (which is fine).
This site has a registry edit which keeps the switch to PIO from happening. Problem is...in my new install of XP, the keys I need to edit aren't there. -
You can always create them in Regedit using New>DWORD>"Name", then modify by right-clicking.Originally Posted by Bix
I couldn't find the keys where his guide says they are, but I did find them.
In RegEdit, hit cTRL+F and search for "primary ide" -- it should take you right where you need to be.
On my machine (Win2K) the keys he talks about are located under: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ass\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0001
but if you aren't comfortable dicking around in your registry, I wouldn't mess with it.
also, check your BIOS settings and make sure that both your mobo and all drives are compatible with Ultra DMA 6"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
That worked swimmingly, thanks!Originally Posted by Xylob the Destroyer
Cant logon to WindowsXP, deleted some registry keys
By chloec42 in forum ComputerReplies: 5Last Post: 14th Sep 2010, 01:26 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 15:45 -
Repairing Registry- Incomplete or damaged info ?? No Optical Drives!!!
By Noahtuck in forum ComputerReplies: 11Last Post: 28th Dec 2007, 23:42 -
Find Firmware for CD/DVD Rom drives?
By Ghtpua in forum ComputerReplies: 8Last Post: 26th Aug 2007, 15:27 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 19:43
