Hello!
I have problem with DVD. It was created in DVDlab. when I insert DVD to player it doesn't play automaticaly. For getting to menu I need to press MENU button on remote. When I press PLAY button then main video play. It is wrong. I want to go to menu in both ways. But It will the best when my dvd will play automaticaly and view main menu when I insert it to player. Where is mistake?
Thankyou for some reaction.
You can probably fix the structure as it it stands using PGCEdit. Look at the guides associated with this tool for details.
If you still have the DVD Lab Pro project then you can open the Connections Page and link the First Play item to Menu you want to see first. You also want to make sure that the Root Menu is chosen for the Menu Button Action for the main movie. Do this by going to the Connections window, clicking on the main movie object, and setting the actions as required.Read my blog here.
