has anyone tried this program yet ? any luck with it ?
this is what i dont understand..... if you have programs like dup-dvd, and dvd2vcd than why go thru the painfull processes of programs like claddvd, flaskmpeg, tmnveng (or whatever it is) and nero. according the the readme files on dup-dvd, it does the entire process for you. has anyone used it ?
Hopefully it rips the dvd to the harddrive and not the read-encode methoid
Nice program does what it says, but the price tag is kind of steep'ouch' $39.95USC, hopefully someone will come up with a working serail on this one...
I've use this piece of software, and it works great. As for the price, yes it is a little steep, but still well worth the cost. Sure saves a lot of problems and work using some of the other ways of doing the same job.
so basically with this program, you can insert a dvd, insert a cdr, run the program, then take the cdr directly to your dvd player.
if this is what your telling me than this program is gold as far as im concerned. i have had nothing but problems ripping dvd's the other way. i have not been sucessfull one time !
i think i'll give dup-dvd a try.
anyone wanna split the cost with me ?
DUP 5990/37 - Pal & NTSC all the time?
By mraroid in forum DVD & Blu-ray PlayersReplies: 18Last Post: 12th Dec 2008, 12:56 -
Toshiba RDXS32 - High speed Dup freeze
By medare in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jun 2008, 13:33
