Hello,
Something weird here. My semi-prof/amateur camera JVC GY-dv301E does do well in recording video and audio, but when viewing on the camera the sound and image doesn't go steady. It goes to slow, than suddenly to fast. As if the tape is going slippery over the head. (Like with those old cassetteplayers where the sound speed goes up and down)
When I do a capture into the computer than Pinnacle can't handle the buggy sound it doesn't report lost frames. and the image is like on the camera not good. So unable to do editing with this material. Pinn :? acle crashes even often on the footage from this camera.
Next thing I tried now for several times is taking the cassette into an other cheap JVC camera gr dvl157E and than capture the footage into pinacle. NO PROBLEMS att all. Video nice, sound nice. well able to do editing with this footage without having pinacle crashing.
Does a camcorder have different heads for recording and reading? like cassettetape players used to have? Somebody experiencing similar problems? Maybe my method to play the tape with any cheap camcorder and record with the better camera helps somebody.
Ewien
COULD BE SOMETHING AS SIMPLE AS WINDING THE TAPE THRU BEFORE RECORDING, HAD A FRIEND WITH A SIMILAR PROBLEM, ALL HE WAS DOING WAS PUTTING A NEW CASSETTE IN AND THEN RECORDING.
Originally Posted by B-Twien Bytes
It sounds like your camcorder is faulty.John Miller -
@ JohnnyMalaria
Thanks for your answer...any suggestions what to do best on the part "It sounds like your camcorder is faulty"?!
Happy 2007 by the way! -
Are you capturing over the IEEE-1394 port? If you use a DV capture program like WinDV do you see the same problems?
What happens if you play a tape recorded on a different DV camcorder?
Assuming the above still produce the problem, try using a cleaning tape. If that doesn't work, try removing both batteries for a cold restart (main battery and small battery that preserves settings). Let it discharge overnight then replace the batteries, set time and date etc. -
I just built on this subject, because I guess it is all related....
I just found out that my footage will play "well" while running it on the videocamera...as soon as I though put it on the computer (Adobe Premiere elements program), it sometimes gives the sentence:
Generating peak file [name scene]
Anyone ever seen a "error message" like above?
hi8 camcorder - awful distorded audio when recording
By HidenSeek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Mar 2011, 21:16 -
Full HD camcorder + MIC Input for recording Lectures
By AjnabiZ in forum Capturing and VCRReplies: 0Last Post: 20th Feb 2011, 20:46 -
Do I need to clean the heads on a Camcorder
By piperpilot12w in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2010, 01:56 -
Q3 camcorder audio level in recording is lousy
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 12:08 -
Sony Camcorder to DVD Recording
By Techguy77 in forum Capturing and VCRReplies: 1Last Post: 25th Nov 2008, 12:56
