hello, i have an avi video where the picture seems flatten, i mean all the figures are small and large. I think i need to increase the height of the picture. I tried using virtualdubmod, and i can get it better... but i don't know what could be the correct height size.
Is there a tools that can help me and that also has a visual resizing or a preview?
Is there a way to find a correct height or width of an avi knowing the other side measure?
thanks
Results 1 to 9 of 9
Use Gspot to get the videos sttributes and put the results here. Most likely either A)the aspect ratio is set wrong, B)your player is not respecting it or C)your player settings are incorrect.
The resolution of a video is not necessarily the size at which it is played. -
here it is:
FILE_NAME (Divx) Back To Work.avi
FILE_NAME_WITH_PATH D:\Video\(Divx) Back To Work.avi
FILE_SIZE 713,262,592
CONT_AUDIO_STREAM_COUNT 1
CONT_BASETYPE AVI(.AVI)
CONT_BYTES_MISSING
CONT_INTERLEAVE_ALIGN Split
CONT_INTERLEAVE_PRELOAD
CONT_INTERLEAVE_TIME 1000
CONT_SUBTYPE AVI v1.0,
CONT_TOTAL_BITRATE 0
VIDEO_ASPECT_CONVERT_AVI1
VIDEO_ASPECT_CONVERT_AVI2
VIDEO_ASPECT_CONVERT_CVD1
VIDEO_ASPECT_CONVERT_CVD2
VIDEO_ASPECT_CONVERT_DVD1
VIDEO_ASPECT_CONVERT_DVD2
VIDEO_ASPECT_CONVERT_SVCD1
VIDEO_ASPECT_CONVERT_SVCD2
VIDEO_ASPECT_CONVERT_VCD1
VIDEO_ASPECT_CONVERT_VCD2
VIDEO_ASPECT_SOURCE_MATCH
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL
VIDEO_BITRATE 1076
VIDEO_CODEC_NAME DivX 3 Low-Motion
VIDEO_CODEC_STATUS Codec(s) are Installed
VIDEO_CODEC_TYPE div3
VIDEO_DAR 1.280
VIDEO_DURATION 1:20:54
VIDEO_FIELDS_PER_SEC
VIDEO_FRAME_COUNT 10485752
VIDEO_FRAMES_PER_SEC 25.000
VIDEO_H264
VIDEO_MPEG2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR 1.000
VIDEO_PICS_PER_SEC 25.000
VIDEO_QF 0.210
VIDEO_SAR 1.280
VIDEO_SIZE_X 512
VIDEO_SIZE_Y 400
AUDIO_BITRATE 96
AUDIO_BITRATE_TYPE CBR
AUDIO_CHANNEL_COUNT 2
AUDIO_CODEC 0x0055 MPEG-1 Layer 3
AUDIO_CODEC_STATUS Codec(s) are Installed
AUDIO_MPEG_STREAM_ID
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE 48000 -
There's probably no way of knowing what the correct DAR (Display Aspect Ratio) should be, you'll have to eyeball it. Look for a scene where there is something with a known shape. A sphere (should always appear circular on screen), a tire viewed directly from the side, etc. Use that to determine the proper aspect ratio.
Hi-
Since it's 512x400, which is 1.28:1, and since a PAL DVD is 720x576 (1.25:1), then some idiot just resized it, but kept the same ratio. If you can find the DVD at a retail place, like Amazon.com, or check at IMDB (or even tell us the name of the movie), then you most likely can find out the real aspect ratio, and will know how to resize it. For example, if it's 1.33:1 (not very likely), then it should be 512x384. If 1.85:1, then 512x288 will be good enough. If 2.35:1, then maybe 512x224 or thereabouts.
And as jagabo said, finding something that's supposed to be round and adjusting the resize until it's really round is a good way. -
ok... the avi is "chicken run" cartoon.... and also... what about tools? is there any visual way to do it? which is the best?
ok, i found the aspect ratio.. its 1.78:1. now? how can i fix it? with what tool?
Just because the movie was shot with an AR of 1.78:1 doesn't necessarily mean your file should have that DAR. Whoever ripped it may have done any number of things to mess up the AR.
Once you know the proper DAR you can fix the video by resizing and reencoding with VirtualDubMod (since you have it). If it's an XVID AVI file you can use MPEG4Modifier to change the DAR without reencoding. Not all players will respect that though. -
The reviews I've read say it's variously 1.74:1, 1.78:1, and 1.85:1. I think you'd be safe using 512x288, or some other resolution with a similar ratio (624x352), with the understanding, as jagabo notes, that you'll never know exactly what was done to it by the original encoder (who didn't know the first thing about encoding, as he made it 512x400 (unless he was expecting you to use your player to resize it)).
Or, as he also says, use MPEG4Modifier to set the DAR without reencoding, but be limited to computer playback, as most standalone DVD/MPEG-4 players won't play it properly.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
Sony Vegas - Picture-in-picture video creation
By jeanpave in forum EditingReplies: 5Last Post: 14th Dec 2011, 00:01 -
Resize video without converting
By JOHNINA in forum Video ConversionReplies: 6Last Post: 27th Feb 2010, 22:25 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
Resize video with n reencoding?
By therock003 in forum EditingReplies: 7Last Post: 3rd Jan 2008, 23:45
