I've been using AnyDVD and Shrink for ages and get good results. I just downloaded the trial of CloneDVD and like it, with the exception of not being able to view a movie in real speed(even at 1x, it's way too fast).
I am wondering if there is any advantage to using this vs. Shrink. Is the image quality the same?
If anyone has used both, could you give your opinion on which you prefer any why. It will help me a lot.
I have a coupon for $10 off Clone DVD, but hate to do it if it's not as good as Shrink.
Thanks for the help!!![]()
Closed Thread
Results 1 to 29 of 29
For the longest time, I was not a big fan of Shrink. Not having used it, I figured that people loved it simply because it is free. Having used it now and comparing it with other programs, I have to admit that there isn't a better program out there. You simply can't beat the quality, but one issue still remains - the time. This is probably why I still use Clone at all. While the quality isn't as good, it certainly is still pretty good. And you simply can't beat the combination of time and quality. Many have said, and I have to agree, that the simplest method has always been to use a combination of AnyDVD and Clone.
US$50 for something that is arguably lower quality, and certainly no better than Shrink (which is free), all for the sake of time. If time is more important than quality, why not buy something cheaper and faster, like ConvertXtoDVD, or even (god forbid) WinAVI.
For me, a little extra time is not an issue, as I prefer quality above all else. And thankfully, with programs like Shrink and encoders like HCEnc, it is possible to produce good quality backups for free, even if it does take a little longer.Read my blog here.
I would spend the money on DVD Rebuilder instead and use the free *encoder* it comes with. It is better than either CloneDVD or Shrink's transcoder.
Originally Posted by Quantum
yup, if someone nowadays still have to go DVD-5 route for backing up their DVD-9s, and doesn't mind spending bit more time on recoding, thats the only user-friendly tool out there.
However best results via DVD-ReBuilder are achieved with Cinema Craft Encoder (which is not free nor cheap)
Jonathan,
I'm someone who uses CloneDVD instead of DvdShrink.
A couple years ago I got the CloneDVD trial, like you, and made a series of test disks, using the two programs, for several randomly selected original dvds. Just to make sure, I made a separate disk for each of the high quality settings in DvdShrink, and one disk with CloneDVD. After playing all the disks, I consistently liked the CloneDVD transcoded disk better, even on the 60" hd tv. Consequently, I bought the program, and have been using it ever since.
As you can tell from the other posts in this thread, not all people share my opinion. Since you already have the trial version of CloneDVD, I would suggest you repeat my experiment, and make your own evaluation. If you use RW disks, all it will cost you is time and effort to determine what works better for you.
Some further thoughts:
The programs use different approaches. DvdShrink will let you set the compression level for each title (which is very nice), CloneDVD doesn't have that. On the other hand, with DvdShrink you take the whole disk, or reauthor, which loses all menu functionality. With CloneDVD you can selectively, quickly, and easily remove (blank) any given title (or combination of titles) and still retain full menu functionality.
These days, I only transcode movies that I probably won't watch many times and honestly aren't worth a DL blank, yet I still don't want to risk damage to the original. I continue to use CloneDVD, though, in conjunction with VobBlanker and PgcEdit to make my backups exactly the way I want them. I even use it when I'm backing up to a DL disk, to bring the overall size down (without transcoding), which brings the layer break in as far as possible from the outer edge, increasing reliability and reducing layer break problems.
Nothing against VegasBud, but it seems a common thread amongst CloneDVD users who bag Shrink's admittedly simplistic re-author mode that they use tools like VobBlanker and PGCEdit to re-structure their discs anyway. Why use CloneDVD's "better" re-authoring tool as a selling point if you are using third party freeware to do the job. Most Shrink users also use these tools, because they are the better option, which makes CloneDVD and DVD Shrink pretty much equal on that score.
Just an observation from watching this seemingly perennial debate over many posts.Read my blog here.
...makes a lot of sense.
I use CloneDVD. The interface and functions are just exactly what I need. After the first try the debate was pretty much over for me. Excellent quality, never an error, fast and easy. What else could I possibly want....? That it was free perhaps... It fits me like an old shoe. And this is damn hard to change. My advice use whatever works for you. CloneDVD is definitely on the top of MY list.
guns1inger,
The reason I use both VobBlanker and CloneDVD for blanking is:
1) CloneDVD lays out the titles in a list, with a checkbox next to each one. Click once on the title, and the preview window shows you what it is. Put a checkmark in the box to keep it, clear the checkbox to blank it. In VobBlanker, you can also preview everything, but (at least to me) it's more cumbersome, in that it takes more clicks to preview and blank, especially since I like the big preview/cut window that pops up, not the little preview window. As a result, even though both programs accomplish the same task (on titles), in VobBlanker it takes a little longer and feels more like work, and in CloneDVD it is quicker and feels more like play. The time saved isn't very much. It's mostly a personal preference.
3) Although CloneDVD works better (for me) on the titles, it uses the "all or nothing" approach to the menus. Unfortunately, they love to hide those irritating warnings in the menu area (mostly in the VIDEO_TS.VOB file), in which case CloneDVD only gives you the choice of menus + irritating warnings, or no menus. VobBlanker lets you selectively blank out those offending PGCs.
By first using VobBlanker to clean the menu area, then using CloneDVD for the title blanking, the "cleaning" part of my workflow (or is it hobbyflow) is made more enjoyable (to me), and slightly quicker, while retaining full effectiveness.
DISCLAIMER:
Everything I've written is just personal observations on a piece of software that I'm familiar with, and Jonathan specifically asked about. None of my remarks should be taken to infer that I think DvdShrink, VobBlanker and PgcEdit are anything but true classic dvd-video programs (regardless of freeware or payware). Furthermore, I strongly endorse the use of freeware/donationware.
I really don't know when for some people it will be finally "worth" to backup their DVD9 disc onto DL discs... when blanks drop to $0.01?
If you decided to spend $10+ on that movie you don't wanna even backup for less than $2 now, then why have you even bought it?
I just don't get it.
Obviously if you have paid $5 or so for that movie then its not even worth to back it up, just buy a second original if you must have backup of it...
Over here DL blanks are still substantially more expensive than SL blanks, and a lot less reliable. With a large % of commercials films, once you extract just the movie, a SL is all that is needed, and the rest, for the most part, need only minimal compression.
Read my blog here.
I have slowly migrated to CloneDVD and + AnyDVD to do my ripping and do almost 100% of my ripping with it. I will use it to transcode down to about 80%. If I have to go more than that then I will use Nero Recode/DVD Shrink to about 75%. Any more than that, then I rip with Clone DVD and reencode with DVD-Rebuilder and CCE. The only time when this formula hasn't worked was for King Kong, it just wouldn't look good on DVD-5 no matter what I did, so I used Clone DVD to break it up into two disks. Overall, though, CloneDVD is by far my most used tool. Luv it!
-Brett
CloneDVD is a quick and dirty dvd to dvd-5 tool, well worth using if you care more about speed than quality. Dvdshrink (a better free tool) is outright better than all those other crappy "jumping on the bandwaggon" tools.
Or for non freeware, get dvd rebuilder (wonderful for high compression).
Originally Posted by guns1inger
Not long ago, when DL blanks were still overpriced, I used to do just that.
Or split it over 2 DVD5 discs.
I will never understand one's need to "compress" any backup, since it is sheer contradiction "backing up".
No one would "backup" i.e. any of their precious old photos to the size of a post stamp just because making 1:1 copies is too expensive at that moment
"Shrinking" DVD9s (using no matter which tool or format) is like "backing up" CD in MP3 format.
No one would "backup" i.e. any of their precious old photos to the size of a post stamp just because making 1:1 copies is too expensive at that moment wink.gif
Second, welcome to America where people can do what ever the hell they want.
Third, do you honestly believe people have to use technology EXACTLY the way you use it?
Obviously there are several reasons why people want to backup their movies onto single layer discs. Just because you can't fathom them doesn't mean they don't exist. One just of the top of my head has to do with COMPATIBILITY. DL discs don't play nice in all DVD players. Thus you might want to use a SL disc.
Then of course there are some people who have a SL burner and don't feel the need to run out and buy a DL player. If it ain't broke, no need to waste your money. Besides it's a backup. Who the hell cares! People tend to make a backup to have a useable copy, especially with children, and they use the backup, not the original.
For the record not all movies need to be compressed when backing up to a SL disc. Especially when you remove all the crap they cram onto a DVD. If you just want the movie - many will fit without compression.
Originally Posted by DereX888
Originally Posted by RLT69
Originally Posted by punisher
Both answer, although elaborated and even trying to be mean (which I dont give a flying f**k about) they both represent failure of understanding basic key word in this discussion, which obviously is "backup".
I apologize if I dared to think people understand meaning of the words they use... so please, don't send US Army after me in defence of your precious freedom (which I didn't even try to threat!)
I switched from DVD Shrink to CloneDVD2 and find this far better especially since DVD Shrink was never updated. I'm just having a problem with some of the menus (separate post). Too many features are 'hidden' with a right or left click. Namely the 'Video bitrate' and 'Frame sizes'.
Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
DereX888,
Dictionary.com has several definitions of the "basic key word in this discussion, which obviously is 'backup'".
To most of us, once a "backup" is made, the backup is used, and the original is kept in reserve. In that situation, the most applicable definition would be:(a) thing that supports or reinforces another
The definition you appear to be using would be:kept in reserve to serve as a substitute, if needed
I don't think that what you preach will have any impact on what and how people do what they do so you may spare us your rants. Thank God most screens are a bit larger then a postage stamp so people can still enjoy their backups.
Originally Posted by InXess
I don't "preach" anything here. I don't give a damn what you or anyone else do.
Out of many possible solutions, making real 1:1 backup is the best solution, not only in my opinion.
If you disagree, you don't have to follow my advice and simply fu*k off, what else is there to say?
Gigabyte Mobo, Input/opinions needed... & a Q on ram for new build.
By Noahtuck in forum ComputerReplies: 12Last Post: 28th Aug 2011, 07:30 -
Opinions about Philips BDP8000/12 blu-ray player needed
By littlewolvie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Mar 2011, 13:03 -
Knowledge and/or opinions on DVDFab and AnyDVD w/CloneDVD
By PCat in forum Newbie / General discussionsReplies: 25Last Post: 6th Feb 2009, 11:01 -
Opinions needed - 'green' Aussie label project wants your help please.
By mlr^ in forum MediaReplies: 7Last Post: 8th Jun 2008, 00:16 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
