I need a scannig guide to export my slides to my pictures to make a dvd slide show using roxio 7. My scanner uses paperport software. I have captured and edited video with good results. sorry if this is the wrong place to post.
Thanks Bob
First you will need a scanner that supports slides. There are some models made specifically for what you are attempting to do.
Google is your Friend -
Hi i have a visineer 6920 with mask to scan slide and film strips I just nead a guide or chart to help me set the reolution and how to scale the output size for a dvd slideshow Bob
For playback on 4:3 TV, scan to 720x576 or similar.
Check out this application : https://www.videohelp.com/tools?tool=MemoriesOnTV
Transfer 35mm slides to DVD
By btruff in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2017, 19:55 -
Scanning 35mm slides and transferring the pictures to a DVD for viewing
By btruff in forum Newbie / General discussionsReplies: 5Last Post: 25th Jan 2009, 11:45 -
Using ProGold to number slides and show this in the output
By cubmar in forum EditingReplies: 2Last Post: 21st Dec 2007, 03:36 -
Scanning 35mm slides?
By videobread in forum ComputerReplies: 1Last Post: 7th Sep 2007, 12:45 -
How to capture 35mm slides
By avz10 in forum Off topicReplies: 11Last Post: 29th Jun 2007, 19:52
