as i understand, i can convert with NERO to a mpg. file.
if it is true, how can i change the setting there?
if not, is mpegnc it realy the best way to convert?
Just drag and drop the avi into the lower left window. Nero will convert it to MPEG, very bad solution.
Use TMPGEnc. instead.
http://www.vcdhelp.com/convert.htm -
Yes, truman is correct. Nero does not allow you to change settings or save the file after it has been converted. USE TMPGEnc.
Converting .mpg movies
By baysee in forum MacReplies: 14Last Post: 25th Sep 2009, 07:11 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 07:59 -
Converting .ts to .mpg (HD)
By tomerwiz in forum Video ConversionReplies: 7Last Post: 8th Nov 2007, 15:48 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 10:03 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 15:08
