if im at the wrong section of this forum, please tell me and ill post my question in another section. im just so new at this that im not sure about it.
here is my story :
i recently purchased a new computer with a dvd player and a cd burner. instantly, the "copy any dvd movie" pop-ups and emails cought my eye. i bought one of those packages for $37.95 and had no luck with it. the company was good enough to give me my money back. anyways, i actually ripped the dvd, converted it to mpeg. can someone please tell me how to compress and burn the mpge file onto a cd-r ?
i have heard so many different oppinions on the subject of copying a dvd that i dont even know if it can be done. has anyone had any luck doing this ?
any and all help is greatly appreciated !!!
Results 1 to 11 of 11
look to the left and follow a tutorial under "DVD RIP"
well, i have followed them pretty closely, but the TMPEng program errors on the cut and merge process. is this process critical ? can i skip the cut and merge with TMPEng and move on to nero and try and burn it ?
another question. it took about 6hrs to convert a 1 1/2 hour dvd into mpeg using flaskmpeg. is this normal ?
does anyone have the seriel # to unlock nero ?
thanks guys. dont shoot me for all the questions. im really new at this and am pretty lost. im just trying to get pointed in the right direction..... -
sorry, after hours of trying to accomplish this, i guess im just getting a little frustrated.......
it seemed so simple in the directions
im having simular problems with burning the mpeg . it burns but no dvd can read it .
Are you sure that your DVD supports vcd's? Some dvd's only support vcd's on cdrw discs, not cdr's. As for the error messages by TMPGEnc. I'm not sure what to tell you. Does the .avi play fine in Windows Media Player? If so, then the cut option should work fine in TMPGEnc.
i have converted avi to mpeg adn burned it , abd it has worked many of times over . this was jus the first time i ripped a dvd to convert to mpeg to burn and it doesnt work . but my stand alone and my dvd rom both read vcd's in the past .
loco:
This whole thing works, it just takes a while to get use to all the different steps. Once you have done it a few times, it becomes pretty simple. It is however, too complicated to describe in a quick response to your post. Go to the tutorials and follow Sefy's first guide. It really is fairly bullet proof.
The key is not cutting or merging the files with TMPGenc at all. Instead, you set the RANGE that you want TMPGenc to encode to determine the amount of the movie that ends up on each disk. Look at the tutorial and it is covered pretty well.
You might also try Ulead DVD Movie Factory which is a free download. I use this just for burning, but also find that it is relatively straight forward.
If the advice of the good people here doesn't help, either give up, or keep trying and ask more questions. -
hi there mate
for the cutting part , use myflix 3 its what i use and never had a problem -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
can someone tell me if these "packages" basically use freeware that we can all get, or do they include proggies like panasonic that we normally have to buy?
Advice needed for 1st time HTPC
By hanugro in forum Media Center PC / MediaCentersReplies: 19Last Post: 17th Mar 2012, 13:07 -
1st time LCD TV buyer
By majax79 in forum DVB / IPTVReplies: 60Last Post: 12th Dec 2009, 18:18 -
1st Post Hello EVERYONE!
By V12V12 in forum Off topicReplies: 17Last Post: 4th Mar 2009, 05:15 -
1st time HTPC - No drives in the case.
By Bronx in forum Media Center PC / MediaCentersReplies: 10Last Post: 15th Sep 2008, 13:27 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
