Hi
I have some avi files, and i have a divx dvd player. I just got a dvd writer with dvd+Rs. Is there a way I can create menus but not convert the divx files. Sorry if this is a repost, i did try to find it on the forums but i was unable to find anything.
thanks
The newest version (6) of DivX includes support for the "DivX" file format, which is an enhanced version of the AVI container format in that it allows storage of accomanying menus and chapters.
Problem is, which players actually would support this new container. My guess is very, very little.
Other than that option, you'll be stuck with converting to MPEG2 and authoring a standard DVD.
At that point, would probably make more sense to just re-rip the original and leave as MPEG2/DVD instead of converting to Divx and then converting back again.
Scott -
Plus you weren't clear if you meant a menu for each AVI or a menu to select the AVI files from. If you meant a menu for each movie that the answer above is right. If you meant a menu for the different avi's then no way since the player wouldn't support it.
To play divx movies with menus you would need the divx ultra certified player. Check out the list from here.
http://www.divx.com/products/products.php
Hope you bought one...
Best format for Xvid/Divx files on DVD
By schematic2 in forum Authoring (DVD)Replies: 3Last Post: 12th Oct 2010, 13:51 -
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 10:31 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
MP4 files in MOV format - how to play in dvd/divx player
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 04:49 -
Multiple Divx/Xvid files on DVD w/ menus and selectable subs?
By louv68 in forum DVD RippingReplies: 4Last Post: 18th Jul 2007, 09:01
