my sony camcorder records in mpeg2 which macs dont reconize.im useing streamclip to convert it to dv,mpeg4, and what ever else but the dvd want play in any desk top players.ive got toast 7,pop corn,dragon and i still cant get the dvd to play except on a computer.so useing streamclip what do i do to get these dvds to work on desk top players or any other program,i dont care.i just want them to play on a table top player.thanks.
Macs certainly "recognize" mpeg2 -- that's what DVDs are encoded in! Certain programs, however, may not natively handle mpeg2 video. Quicktime, for example, requires an upgrade (via a transfer of $$ to Apple) to do so.
If your sony outputs dvd-compliant mpeg2, then it sounds as if you only have to author the file as dvd, then burn the result. FfmpegX does a fine job of authoring. And you already have Toast, so you should be good to go.
Another thing to check is whether your standalone player can play the particular type of disc you're burning. Some players are very fussy about which media they'll accept. For instance, some will work with DVD-R, but not DVD+R, or vice-versa, and sometime only with certain brands. Computer drives tend to be a bit less fussy, so that can also explain why your burned dvds are readable in your computer, but not by the standalone player. -
I believe VLC will play the mpeg2 files. Alternatively, pay Apple the $20 ($30?) for their MPEG2 component. It does work great and lets apps like MPEG Streamclip work with such files in order to trancode them for iPod (for example). Worth the money.
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
I have a problem, player cant play DTS... need to convert
By Chrushev in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2009, 02:56 -
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 13:31 -
Trying to convert MPEG2 file to work in a Philips 5980 DVD player
By JohnWB in forum Video ConversionReplies: 3Last Post: 31st Mar 2008, 07:16 -
Convert .avi to play on a DVD player
By Aaron1978 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2007, 13:06
