I use AnyDVD to rip my DVDs to my harddrive and this is the first time I've seen Slysoft recommend that you don't use AnyDVD to rip. Is this a marketing ploy to get users to buy CloneDVD or are there other legitimate reasons. I find the above statement a little troublesome.Originally Posted by [url=https://www.videohelp.com/tools?tool=AnyDVD
anydvd is not a ripper. it is a copy protection remover. if he can get a few more sales of clonedvd out of it why wouldn't he try to promote it as a ripper to go along with anydvd. it's possible there is a movie it does better than a straight file copy with windows, but i can't see any pressing reason to use it either nor have i needed it.
Originally Posted by aedipuss
AnyDVD does have a ripper and it's different (or appears to different) than a staight copy in that it can remove unreferenced and blank cells.
I've been using the AnyDVD ripper with that option checked for a while now without problem.
I'm just curious why all of a sudden the recommendation to use CloneDVD to rip now appears in the AnyDVD changelog. -
All I know is this: Look at the RipIT4Me forums, Using AnyDVD followed by FixVTS, I had the first successful WORKING rip of Attack Force. FBI, INTERPOL, sony splach, then movie - all other looped the first two. Whatever the tool does, it does well.
The guys at RipIT4ME (great work) spent two days hard work on that one - Slysoft had it already - no updates, just the download from the site.
Anyway: Why only get $39 when you might get double.
No problem with their products (except when pushing CloneDVD on an encode - blockiness) as they update more than many.
If you do use the AnyDVD ripper, you need to run FixVTS - that may be what Slysoft is trying to avoid by recommending CloneDVVD.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
If you have problems with bad sectors I found something at SPAM Good luck I hope you will resolve your problem.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick -
Part of the issue here is that CloneDVD2 is able to handle some problematic artifacts sometimes left behind by AnyDVD that makes programs like DVDShrink gag. So, although I'm sure Elby/Slysoft would love everyone to buy both AnyDVD and CloneDVD2, there is some logic behind using CloneDVD2 when ripping with AnyDVD in the background, since CloneDVD2 cleans some things up as well. Of course if AnyDVD simply took care of all the issues which make programs like DVDShrink gag, that would be better still, for those who are determined to use DVDShrink.Originally Posted by rkr1958
DVDfab plate or Anydvd+clonedvd
By charlesnj2009 in forum Newbie / General discussionsReplies: 10Last Post: 29th Jun 2009, 15:10 -
Knowledge and/or opinions on DVDFab and AnyDVD w/CloneDVD
By PCat in forum Newbie / General discussionsReplies: 25Last Post: 6th Feb 2009, 12:01 -
AnyDVD BlueRay Rip - What Can I do with it
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 24th Mar 2008, 14:03 -
Which is better DVDfab or AnyDVD/CloneDVD?
By Vrex in forum DVD RippingReplies: 17Last Post: 23rd Mar 2008, 21:46 -
Which is better Anydvd+clonedvd or Dvdfab platinum? Thanks in advance!
By gary11364 in forum DVD RippingReplies: 1Last Post: 24th Jun 2007, 05:25
