  1. Member CilyPudi's Avatar
    Aug 2006
    Question is, if I recieve a MP3 file ripped at say 128kbs, then run it through my Switch program to convert to 320kbs, is there any benefit in doing this?
    Also, when I convert a FLAC or APE file to MP3 using Switch, does it affect quality if I convert to 128kbs or the 320kbs setting, considering it has already been ripped. I'm trying to conserve space but save quality.
    CilyPudi thanks in advance.
    never implant the VeriChip.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    If the file is already 128kbs then converting to 320 will not make any difference, you can't put the original quality back.
    FLAC and Ape are lossless so they should be the same as the original. Try encoding using mp3 VBR.
    He's a liar and a murderer, and I say that with all due respect.
  3. Member CilyPudi's Avatar
    Aug 2006
    Thanks steveryan.
