I have a PC TV Tuner and I record shows frequently but then I have to either watch them with ads or go through the process of cutting the ads out, then resaving them and then having to convert them to Divx. It's very tedious and time-consuming so I was wondering if there was a program that made cutting ads out easy/easier and could also make the output file a good compression file format like Divx or similar. Thanks in advance!!!
groggit,
With respect to cutting out commercials from TV shows, I have had good to excellent results using VideoReDo. Although I capture straight to MPEG2 and VideoReDo does a good job with this format, I am not certain about coverting to Divx, since I do not use that format.
Ed -
VirtualDub MPEG-2 should do the trick for you, It's free and not too difficult to learn.
Your DVD player has a fast-forward button. You can skip them while playing. I do this too, when I get lazy or impatient.
Need ads tech's Capwiz program, cant access website =\
By edge2k in forum Capturing and VCRReplies: 18Last Post: 21st Nov 2014, 17:12 -
which is the best Program for making Youtube 'music' Vids?
By snadge in forum EditingReplies: 1Last Post: 11th May 2011, 13:00 -
890922 - How to cut a DAT file out of ads?
By hamidi2 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2010, 09:41 -
Recorded video, i want to cut my self out of it.
By aiitexx in forum Software PlayingReplies: 2Last Post: 13th May 2009, 20:55 -
Noob trying virtualdub and avisplitter to cut avi vids
By majax79 in forum EditingReplies: 2Last Post: 22nd Dec 2007, 09:24
