How do I make the background tranparent in after effects I am useing 7 if that helps but I am sure that this process is the same please help me out on this.
I just want to create some moving text in which I have already Created but I want to save it with out the back ground showing meaning an tranparent background
Nevermind I have figured it out what you want to do is when you are saving it you wanna Choose Millions of Colors+ so that you include an alpha channel to make the video transparent. That is if you are saving it as an avi I havent tryed any other way of Expoting the file I will keep this page updated with my progress.
Usually the best way to export a movie file is Quicktime Animation, uncompressed (Which I think can be used without AVID's Codec).
Once trick is to export a TARGA Bitmap sequence with the alpha channel included.
A program that create transparent animation
By Cazz in forum EditingReplies: 11Last Post: 5th Jun 2011, 14:08 -
subs look transparent (sub/idx)
By X_Splinter in forum SubtitleReplies: 2Last Post: 22nd Dec 2010, 11:26 -
How to filter out a ground buzz
By pdx10 in forum AudioReplies: 4Last Post: 24th Mar 2009, 10:14 -
DVD logo with a transparent background
By cobra jet in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 16:31 -
Ground Loop problem. Subwoofer hum. Will this gound isolater work on HD
By Denvers Dawgs in forum DVB / IPTVReplies: 3Last Post: 17th Jun 2007, 00:43
