I have limited desk and room space. I would like to know if there is a switch or something that I could use to have one monitor for two computers.![]()
I could have one converting, etc., while the other could be used to do labels, e-mail. etc.
This would be a time and space saver.
any info would be apreciated.![]()
Google search for "KVM switch".
Buy My Books -
You'll like it. I use this KVM switch for my two machines and can't imagine doing without it
http://www.bestbuy.com/site/olspage.jsp?skuId=7708527&st=kvm+switch&type=product&id=1138086034838 -
Here is how I do it....
1. Get a LCD Monitor with analog and DVI inputs
2. Connect 1 pc to the analog input and another to the DVI input. At least, one PC must have a DVI output videocard.
If one pc is ON at a time, the LCD monitor can auto detect. However, if both PCs are ON, then you have to manually select the in the input source in the LCD monitor setting.
@capmaster,
Your new avatar... is that a John Travolta move ? -
That takes care of the video, but you will still need to deal with the keyboards and miceOriginally Posted by pchan
No, that's some dancing video clip I got off the net and cloned my own head onto
Here's the full version:
http://convopit.org/images/anim_me_dance2.gif -
I've used a KVM switch (automatic) with wired keyboard & mouse.
The one I have now has single monitor, but wireless KB & mouse thru one USB connection.
The only hassle is if XP forgets what is attached, and I have to go into control panel and do an uninstall/refresh if I get into too big of a hurry when booting.
Other than that, if it loads the drivers, it's nice.
I likely picked it up online at geeks.com or similar;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Multiple computers?
By DGenerateKane in forum ComputerReplies: 3Last Post: 25th Apr 2011, 10:28 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
RE: PS2 control switch 1 K/M & mouse from 2 computers to 1 monitor ???
By blinky88 in forum ComputerReplies: 4Last Post: 2nd Oct 2008, 12:23 -
Your computers. Show them to me.
By Faustus in forum Off topicReplies: 29Last Post: 20th Jul 2008, 12:43 -
Computers and sd scard
By CapeKO in forum ComputerReplies: 1Last Post: 16th Mar 2008, 17:17
