I NEED A REMOTE HACK ON A SAMSUNG HT-P38
Seeing as you have asked so politely -
1. Open tray and remove any disks in tray.
2. Close tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Allows ALL REGIONS DVD's to play.
I SEARCHED the hack section on the left and found that.He's a liar and a murderer, and I say that with all due respect. -
What the hell is a remote hack? And btw, turn off the caps lock, it's very annoying.
ill turn off caps you stop curseing at me and we will be even hows that. and what i need is the remote code for it.
Sony BDP S370 DVD region hack - which remote to use!?
By bubbafurn in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2017, 06:49 -
Momitsu 799 remote hack
By ojopaj in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Mar 2010, 10:00 -
Sony DVPN S708H hack using the dvd remote
By desertoil in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Apr 2009, 18:22 -
GoVideo DVP853 DVD Hack with One For All 4 Remote ??
By culttvguy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 13:17 -
DVD+R's skipping/stop & starting on Samsung HT-P38 ?
By dch1028 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jun 2007, 16:22
