  1. How do you rip just the trailer or behind the scenes from a DVD?
  2. hi,
    Most of the time when you take a look at the files on the dvd there is a set of big files. For example 3x1Gig and 1 of something less than 1 Gig in a sequence. The trailer(s) are ussually a lot smaller and in a different VOB file. What you can also do is rip the complete DVD (using smartripper) to your hd, and play the seperat VOB files in your dvd player. I use PowerDVD 3 and this works great.
    When you figured out which files you want, just do the same with those as you would ripping the movie.
    Greetz,
    pSyChO dAd
    _________________
    The difference between genius and insanity is only measured by success !
    <font size=-1>[ This Message was edited by: Psycho_Dad_Rules on 2001-07-20 00:12:42 ]</font>
    Jul 2001
    What I do is to look at the title\chapter and take note of it and find out how long it is. Then I use that information when using a DVD ripper program (like FlaskMPEG)It's a little confusing at first but you'll get the hang of it!
  4. Thanks Feslmogh. I realized that after I posted the message. It was smacking me in the face
  5. Thanks Feslmogh. I realized that after I posted the message. It was smacking me in the face
  6. What I do is list the vob files on the DVD by size (it is immediately clear which are for the movie: at least four 0.99GB files following somewhere by the last that is somewhat smaller).
    I make note of those "big" vob file that are not part of the movie (different numbering).
    Make a playlist of them in WinDVD and play them - each vob file represents a chapter.
    Quickly run through the chapters and note the chapter number I need.
    Identify the vob file in the playlist using the noted chapter number.
    BeTa
