I am trying to convert a .ts that uses h.264 as the codec. I created an avisynth script for it and able able to load it. The problem I get is when converting it the audio and video are always out of sync, no matter which framterate I choose. The .ts stats say it is 29fps 1080i. However when watching the video the fps states around 23-24, so I believe the framerate 23.976 with a pulldown for NTSC video. Am I doing something wrong that is makign the audio and video go out of sync. I thought in tmpgenc whatever framterate you choose it keeps the same timecode. Any help would be great. Thank you
Try AviMux-Gui. Drag and drop your video into the top window, click it highlighting it and select "generate data" Now, in the lower window click audio highlightiing it and any delay will appear in a window to the right. If other than 0, select save naming and saving as you wish and in about 2 minutes you'll have a new file to use.
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Authoring Works 4 Encoding
By mabrandt in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2009, 10:45 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
