I have numerous video clips in various media and am having trouble assembling them into a DVD that will play on my DVD player. I use Nero 7 to put the clips together and burn the DVD but when I try to play the disk it will play for awhile then freeze up. I seem to have clips that are 352x240 or 720x480 but I don't know much about what that means. Disks seem to work better with the 352x240 clips. Any suggestions?
Have Nero save to a HD folder first, then play them and see if they are working properly.
You might also have borderline media. What kind are you using?
It also sounds like you are using Nero to convert your clips into dvd format. Nero often has issues doing conversions, try another app such as Convertx2dvd.
Google is your Friend -
Best to find out who really makes the discs. I've had Imation discs made by Fuji and Fuji discs made by ProDisc.Originally Posted by jcjohns91107
http://dvd.identifier.cdfreaks.com/
need help regarding dvd clips
By lullaby49 in forum EditingReplies: 1Last Post: 13th Mar 2011, 04:28 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
??s About Ripping and Re-assembling a DVD
By x002657 in forum DVD RippingReplies: 0Last Post: 3rd Mar 2009, 00:18 -
Clips for DVD's?
By pianoman1976 in forum MacReplies: 2Last Post: 30th Jan 2009, 20:52 -
What is the best way to gather clips from various DVD's?
By JediPM in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 11:30
