Hi all,
I'm having a problem playing burned vcds on my philips dvd 711 player. I live in Brazil where the tv system is PAL-M. My TV is a SONY 21' that allows the user to select the system to NTSC or PAL-M (Not PAL-N/B/G). I burned a Nero image file of European PAL VCD (25 fps/50 Hz). The VCD image was downloaded from a internet site (not authored by me).
The VCD plays only in B&W, and at each ~10 seconds it freezes for one second, then returns ~2 seconds back from the point where the movie freezed. The VCD plays this way on the entire movie.
I Know that the B&W problem is related to the PAL/NTSC compatibility with TV. But the freezing problem I don't know what is related with.
I burned the VCD on a cheap green CD-R media and on a gold KODAK CD-R media. The problem is the same with both.
I tried also to switch the system (PAL/NTSC) from the TV and DVD, but no results.
The DVD is conected to TV by its composite TV conector. There's no s-video or component video conectors on my TV.
I would apreciate some help here. What's the trick with this NTSC/PAL-M/PAL-N/... thing? I also expected that the picture rolls off on the TV, but this does not happens!!??
Eddie
You just can't play a European Pal VCD in a Brazilian Pal-M system. You must to convert a file to NTSC format and burn it again.
Why not Jpsilva?
I think if someone plays a pal-n vcd on a compatible dvd player using a tv that accepts pal-n (Sony VEGA 29'' can do it), sure will be fine, isn't it? Or in Brazil it isn't possible?
Eddie. -
Hi everyone,
I have the same problem with my VCD's, but I don't live in Brazil and I use a Philips DVD 710 to playback my burned VCD's. On my computer it works fine, except the audio. After the movie freezes, the audio is out of sync for a second or two, but it recovers.
Is this a typical problem for Philips DVD players?
Regards, Ralf
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Is it possible to have G.711 audio in an H.264/mp4?
By Jean777 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 17:53 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
