Results 1 to 10 of 10
  1. When i am finished a movie with the program convertXtodvd the movie plays in DVD but it seems to stop a bit about every seconds. Is this normal or if not , what can I do to fix it?
    Jan 2003
    Toronto,Canada
    Try burning to better media. It could be that simple.
    Everytime I tried to burn from Convertx to cheap media like the godawful Dataware, it resulted in pixelation during dark scenes. Burned to Verbatim the video plays perfectly.
  3. Hi. The problem is that I try to play it on pc first and the same problem appears.
  4. Mod Neophyte redwudz's Avatar
    USA
    I assume you mean you play the video file from ConvertX before burning?
    You may have a corrupted video file. I assume a format like Xvid? If so, drop it into VirtualDub Mod and check it for errors. You may be able to save it out with VDM as a new file with Direct stream copy and fix it. Or, worst case, re-encode it with VDM to the same format. That fixes most problems.
    Software players can ignore some errors that may show up later on converting to DVD and burning. VLC Media Player, for one, can play corrupted or partial video files.
  5. Yes...I try it before I burned it after using this program. Its the same , xvid , avi whatever ..the same problem appears. I also try super dvd creator but same results.
  6. I tested WinAVI Video Converter and it looks like it didn´t have the same error. Can I use subtitles files with this program too?
  7. Banned
    Jan 2007
    Singapore
    do you installed the trial version super dvd creator ? it just limited 5 mins converting .
    the burner and authoring function is total free but the converting function need 29.90 usd.
    the company company http://www.alldj.com/index.htm did not tell me it limited to 5 mins when I burn the first DVD with it .
    and another question : how to add 2 subtitles streem to DVD with super dvd creator ? I can only and one *.srt file, but how to add 2 subtitles ,such english and france both in it ?
    and how to creator 100 chapter title ?because I need to add more than 100 avi and divx or rm to one dvd ,every clips just 3-5 mins.
    anyone ??
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    @Wolfmania : Are you converting PAL to NTSC or NTSC to PAL ?
    Personally, I wouldn't use WinAVI to wipe my butt.
    @JackAuthor - please create your own topic, as you post has absolutely nothing at all to do with the Wolfmania's original or subsequent posts. This is called Hijacking a Thread, and is frowned upon in all organised forums.
    Read my blog here.
  9. Mod Neophyte redwudz's Avatar
    USA
    jackauthor, I have to agree with guns1inger. Please create a new post if you wish to discuss 'super dvd creator' or a subject not directly related to the original posters question.
    Moderator redwudz
  10. Banned
    Jan 2007
    Singapore
    maybe you need to see the DVD Timestamp when you play your DVD on home DVD player. if the Timestamp jump too, then it because your DVD player is toooooo old to read a tinpot DVD Disc Media . sorry.
    but if the Timestamp did not jump then it because the Converter software,it droped some frame or the converter is bug fill .
