someone was saying, in a message in a forum, that they had a video card, which had a coaxial cable jack, which let them capture ANYTHING from the internet. All they had to do is connect it to a vcr, and voila! I am wondering if something like this exists, and where to purchase one. Anyone got any ideas?
There are plenty of video cards that have coaxial inputs, but that is for a tuner input from a TV signal. I'm not sure where the internet would come into it.
And there are video cards that have coaxial output, but that is generally referring to SPDIF digital audio out.
Alternately, they may be talking about the output of a cable box, but that would probably be a composite output or a MPEG HDTV signal. Still, that doesn't relate to the internet.
Or they may be saying they can capture whatever is displayed on the monitor from the internet, but that can be done with software. Or they may be converting the VGA or DVI signal from the video card to a composite or S-video signal out to a VCR. That is fairly simple and just needs a video card that has 2 video outputs. Don't expect great quality that way, though. Not much different than sending the computer video to a TV.
They would have to be more specific about what they are 'capturing'. -
yes, that's what i was meaning to say. The video output is displayed on the tv monitor, or recorded on a vcr. I don't know how good the quality would be, but with all the "protected" content out there, it sure would beat it. I don't know how to get some pretty good quality video from protected internet videos any other way.
Do it all the time here ...
Via video cards tv out to vcr .
Either via cloned display mode , or via application to tv only (work on pc while watching video on tv) .
Internet , software , and pc game recordings .
I even have the geforce 6600 tv output working in pure dos ... the frequency needs modification here as it's double the rate required for the tv ... good for bios / pure dos recordings .
For screen recordings in os , the screen res needs lowering to 800x600 ... as dvd is below this scale ... there is still noticable lose in quality ... fonts mainly , should these end up being used for dvd projects ... improvement is done though the dual pass encoding ... or even quad pass encoding .
Some programs are impossible to use unless one knows the keyboard nav commands used by each application , as buttons on the bottom of some tools will remain off screen in this lower res format .
Vga conversion box's , while they can be expected to work within reason ... affect the clarity of fonts and icons on norma pc screen .
So , you want to have either :
1: A vga graphics card with tv out function
or
2: A vga to tv conversion box
Plus cable and vcr ...
Back to pc via capture device ... either built into vga , or pci / usb .
Hauppauge 350 - Capture with Coaxial / S-Video / RCA ???
By samusaran in forum Capturing and VCRReplies: 17Last Post: 30th Jun 2010, 09:58 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 17:10 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 09:38 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Video Card with Coaxial Out
By cblythe303 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2008, 13:38
