which is better, easier, takes less space for transfering movies
mini dvds or miniDVs because i cant find a camcorder with both
i want to be able to put stuff on youtube n stuff like that
and is this one good for that
http://www.walmart.com/catalog/product.do?product_id=4725824
thanks
Probably minidv is better. Can't comment specifically becuase all I have is the last generation of 8mm (non hi8) anlaog.
With minidv you can get 1hour tapes. I believe minidvd is limited to 20minutes at top quality. THat may have changed recently since the last time I looked at them.
Two things to note -
Mini dvd will let you pop it right into a dvd player without authoring or editing. BUT you will have to copy it to a computer anyway if you want to rearrange stuff and create menus and such.
Mini dv requires firewire inputs for optimal transfer. USB 2 can be used but from what I have heard on this site the quality takes a huge hit. And minidv takes a lot of space. I believe its 13gb an hour.
I believe they should be more or less equal in quality however. Just be sure to check the size of the ccd (the charged coupled device - the actual unit that determines the quality of the video). the bigger the ccd the better the quality - I'm pretty sure thats how it works.
Check out consumer reviews on tech sites like www.cnet.com and don't forget to do a forum search here for the model you are thinking of. It may already have a lenghty thread discussing it.
Good luck and don't forget to actually go to a store and compare the models in person. Little things like the position of buttons or hand grip feel can be a deal breaker or maker when your deciding between two or three models.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
want too capture movies from analog camcorder into computer
By shashgo in forum Capturing and VCRReplies: 3Last Post: 7th May 2012, 06:19 -
Trying to transfer camcorder tapes to computer via easycap *RAAAHH!*
By BostonJas in forum Video Streaming DownloadingReplies: 9Last Post: 31st Aug 2010, 18:24 -
transfer from camcorder to computer
By stratman in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2008, 10:07 -
Transfer home movies from analog camcorder to Mac?
By cali891 in forum MacReplies: 4Last Post: 8th May 2007, 08:59 -
By cali891 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 7th May 2007, 14:18
