Hi from Paris, France,
I'm using ffmpegX on my G4 for converting mpg files to dv in commande line for batch.
When I try to do the same on my new mac mini intel based I have an error :
On /Library/Application Support/ffmpegX I have :Code:/rf/applications/ffmpegX_0.0.9x/ffmpegx.app/Contents/Resources/ffmpeg -i /rf/mpg/bloom_2006_12_25.mpg -target dv /rf/dv/bloom_2006_12_25.dv FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264 libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250) Input #0, mpeg, from '/rf/mpg/bloom_2006_12_25.mpg': Duration: 00:00:57.7, start: 79765.444233, bitrate: 2144 kb/s Stream #0.0[0x1c0]: Audio: mp2, 48000 Hz, stereo, 192 kb/s Stream #0.1[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 544x576, 104857 kb/s Assuming PAL for target. Output #0, dv, to '/rf/dv/bloom_2006_12_25.dv': Stream #0.0, 25.00 fps(c): Video: dvvideo, yuv420p, 720x576, q=2-31, 200 kb/s Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s Stream mapping: Stream #0.1 -> #0.0 Stream #0.0 -> #0.1 Press [q] to stop encoding Illegal instruction
Have I missed something ?Code:gocr gocrfilter_en.sed gocrfilter_fr.sed gocrfilter_nl.sed gocrfilter_none.sed mencoder mp2enc mpeg2enc mplayer subtitle2pgm tcextract vcdxbuild vcdxgen yuvdenoise yuvscaler
thanks for your help,
Alex
Script to mass convert VOB's to MPG's from the command line
By casperinmd in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 3rd Jan 2013, 16:08 -
Linux command line tools for Converting AVI to H264/AAC mkv
By Psykro in forum LinuxReplies: 9Last Post: 6th Oct 2011, 21:21 -
Command line convert mpg to mp4
By csc12345678 in forum Video ConversionReplies: 1Last Post: 30th Dec 2010, 09:11 -
command line for converting AND watermarking from any format
By 2diabolos.com in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2010, 13:17 -
any (free) command line tools for converting swf to other formats?
By kkol123 in forum Video ConversionReplies: 1Last Post: 7th Dec 2008, 22:42
