    Dec 2006
    Originally Posted by brownstem
    Found this player at thetechgeek.com: http://www.thetechgeek.com/content/product.php?pid=7696&cid=112
    Can't find a website or any info about it, but noticed that it had a USB port. I called TheTechGeek and they said it's a 2.0 port and that an external hard drive can be attached to play mp4 files through the player. If this is true it makes it a very nifty device. Anyone know anything about this player, or if it's the same as one sold under a differenet brand?
    Hello
    I have a different problem. It will not play reqular DVD. The error message it gives it "DISC is not formatted to play region" or something like that. If anyone know how to make it play DVDs please let me know.
    Many thanks.
    I bought it from http://www.thetechgeek.com/content/product.php?pid=7696&cid=112 and I have sent them email about this shoddy product.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Please don't wake up old threads just to make a new question - start your own new thread. I've split this out for you.
    /Mats
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Are you using original discs or copies? Have you tried more than one disc?
    The correct error code would also be helpful. From your description above, it sounds like a bad disc or a disc from the wrong region (This player should support at least region 1).
    Google is your Friend
