Dont you love xmas and kids....Ok i bought my daughter ythis mp3 player,i installed the driver disk.When i try to put a mp3 or wma file onto the disc i keep getting that the disc is write protected.
This mesage when i try to run the driver update tool or try anything else (like formating the disk)with the mp3 disk....
It may just be something im overlooking or the players disk is naff.Any help much appreciated...
Hello! One thing to try: if there is a "hold" switch" if its on it will not allow you to write anything to the mp3 player, moving it off should allow tracks to be put on it.
Worth A Try -
Exactly, check the manual for a hold switch. That will in effect write protect the drive. I know IPODs have such a switch.
Don't you just love the fractured grammar in the in the Information window you posted. Should have been "disk is write protected!" Not as bad some of the text I've seen in Motherboard Bioses or Personal DVD Player manuals made in China. -
Thanks for the replies.I have managed to work it out,with your help.On the mp3 player there is a option for system,if you go into that you will find the disc is locked you have to set the disk to normal...geez
thanx
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Pioneer-to-Bluray, BD-RE works, BD-R "cannot play disk" on Samsung player.
By spinningdisk in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 18:00 -
"data disk" rather than as an "audio disk"?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 09:10 -
dvd player reads "no disk"
By VINCIBLE in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Jul 2008, 12:56 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
