Even though the subtitle stream is set to "subtitles off" in the playlist for each of the movies, and even though it works just fine in the Simulation, when the DVD is burnt the subtitles automatically play. They are also shown in the animated buttons on the menu. Has anyone had this happen or have any idea whats going on?
Subtitles can be set initially "on" or "off". But if neither is set, it depends on the player's defaults. Many players default "on".
You may be able to change the commands to explicitly off in your authoring app, but a fairly easy way to fix is to use PGCedit on the IFO files before you burn.
See this guide for details.
In most cases it's very simple, for each title insert a new "pre" command, then edit this, choose "setSTN" and "set to none".
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 08:21 -
Stream type mismatch - 19023 with DVDit Pro 6 Redux
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2010, 18:24 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 23:40 -
Setting Specific Subtitle Stream -On- by Default.
By GangstaRap in forum Authoring (DVD)Replies: 7Last Post: 16th Jan 2009, 20:50 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18
