I used Microsoft Photo Story to make a picture slide show. I saved it using the highest setting. I recorded it using my Gigabite DVD +/- RW. When I watch in on my TV some of the pictures are wavy (seem to have a motion in the picture). I can't figure out what I might have done wrong. I recorded it twice, first using the automatic recording speed and then again using a 2X speed. Actually the automatic is better but not good. I would appreciate any suggestions to remove the wave. Thank you
Without seeing it, it is hard to tell what's going on. One thing to note - the built-in templates for both Photostory and WMM are pretty awful. Papa John's site (papajohn.org) has better output templates for both, and they do make a hell of a difference to the image quality you get.
Read my blog here.
I will take a look at papajohn.org but don't think that is my problem. I made the video using Photo Story but recorded it to DVD using Nero (which I should have said). Thanks for the reply.
I suspect you have a combination of lower than expected quality output from photostory, badly re-encoded by Nero. Start by using Papa John's templates to get higher quality (and DVD resolution) output from photostory, then use anything but Nero to encode and burn. I would suggest a good standalone encoder, but ig you have Vegas or similar, that will do a much better job than Nero.
Read my blog here.
Capturing in MPEG Gives Wavy Video
By MasterOfPuppets in forum Capturing and VCRReplies: 18Last Post: 7th Jul 2010, 08:22 -
Wavy video
By steebee in forum RestorationReplies: 20Last Post: 31st Jul 2009, 00:56 -
wavy line distortion in .avi file - how to remove
By abeelandig in forum Video ConversionReplies: 2Last Post: 21st May 2009, 04:01 -
Wavy lines on tv reception (tapes too!)
By JudgeGarth in forum DVB / IPTVReplies: 4Last Post: 27th Feb 2008, 11:56 -
DVD rip /avi thru MTR /FFmpegX - get wavy lines
By BattyRoy in forum MacReplies: 5Last Post: 31st Aug 2007, 10:06
