I need badly an advice from you.
I burned a DVD-R with video clips. I put 24 video clips burned at Long Play/Progressive/High-Quality 2-pass VBR/LPCM settings in my NeroVision Express 3.
I am using a Plextor PX-716A, Verbatim DVD-R 4.7/16X/120min video media. Settings in Nero are set to fit the DVD.
Actually, before burning, the software shows about 1.1GB of free space left on DVD. On the DVD you can see the empty space. The file burnt on DVD is in TS VIDEO folder and it works fine on the PC. I can see all the video clips and it does not stop.
When I play it, I am using a Samsung DVD player DVD-P421. It is not great but is decent. After 11 clips, it stops and if I try to play the next one, it refuses the command. If I go into the menu, it shows all the 24 videos and if I try to play any of them from 12 up, it refuses to play.
Please help ! I am trying to make a present to somebody dear tonight and I cannot figure out what the problem is.
Thanks in anticipation
NERO sucks at anything DVD related other than DATA DVD burning.
You need to learn other method of conversion and authoring.
If you want a simple all-in-one solution then check out ConvertXtoDVD
how can i add multiple video clips to play as one dvd???
By Banleno007 in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 10:53 -
Newby question: 25 video clips on a DVD. I want to play one at a time.
By keeskeeskees in forum Video ConversionReplies: 5Last Post: 19th Feb 2011, 20:32 -
Can Blu-ray DVD player play both of photos and video clips from an SD card?
By coody in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Dec 2010, 12:11 -
Video Clips to DVD
By MeDiCo_BrUjO in forum Authoring (DVD)Replies: 6Last Post: 5th Nov 2007, 23:55 -
I can't play HDTV Clips on my PC !?!
By Soreen in forum DVB / IPTVReplies: 11Last Post: 11th Jul 2007, 03:19
