The quality when i convert from PAL to NTSC realy seems to go down, i do not know why? I use TMPGENC to convert with the NTSC(video) template loaded. Has anyone ever heard of this?
Hi,
Even using the TMPGEnc you will have problems with the frame rate, wich is 25 fps for PAL and 30 fps for NTSC. The process is:
- Demux A/V, you can use the Tools section on TMPGEnc;
- Deinterlace and resize (720x480 for DVD, 480x480 for SVCD, 320x240 for VCD) the video;
- Pulldown video to 2:3, the video will be 24 fps, but played with extra frames at 30 fps;
- Stretch the sound in about 4%, use some audio tool, like Sound Forge;
- Mux A/V;
It's not necessary to tell that you will loose some quality in the video and audio. I've done once with a DVD, it's was acceptable for a SVCD.
Regards -
If your dvd player(made in ROC) reads PAL and auto-output to TV/NTSC, I would leave it be. You're adding frames, stretching audio, etc. U mite end-up with an 900meg mpg and have to use 99min cdr's. Why do that?? Save the hours downloading more vids.
PAL MPEG-2 to NTSC MPEG-2 - Different Color on TV
By HoosierGuy in forum Video ConversionReplies: 20Last Post: 5th Apr 2011, 12:43 -
Conversion from mpeg-4 ntsc to pal
By cagacayak in forum Video ConversionReplies: 8Last Post: 27th Jul 2010, 03:40 -
Converting Videos to NTSC MPEG-2 (using TMPGEnc Xpress)
By Quamatek in forum Video ConversionReplies: 14Last Post: 12th Sep 2009, 05:20 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 15:07 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06
