Good day. I just secured a copy of Pinnacle Express to make VCDs. It only accepts Type II avi files. I have a few avi files that I made in ULead 3.0 that it won't accept. So, is there any way to convert these "normal" or non-DV avi files to the Type II DV? I've trie some of the utilities mentioned here, but they either don't do it, or I'm doing it wrong. Or, am I just in over my head?
ulead studio pro will convert dv1 to dv2. but why not just use tempnec to convert dv1 to mpeg vcd format?
I think that a part of my problem is that the originals are not DV1. I have a utility to go from DV1 to DV2, but when I try to convert the files that I have I get an error message saying that the program will only accept "DV avi files."
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
3 gb avi file containing 1 min of footage, is it normal ?
By codemaster in forum EditingReplies: 2Last Post: 2nd Jan 2012, 10:46 -
Is it normal? mkv to avi increase in size.
By Vitto in forum Video ConversionReplies: 10Last Post: 5th Sep 2011, 09:57 -
720 FLV file to normal avi?
By jake25uk in forum Video ConversionReplies: 3Last Post: 17th Jun 2010, 17:46 -
How to convert a DVD to a NORMAL AVI file using XviD4PSP?
By coxanhvn in forum DVD RippingReplies: 3Last Post: 8th Jan 2009, 15:31
