Hi,
I am getting coasters from the last few weeks now. I have been burning with the same drive on same disks and on same machine for more than a year now. Never had a single coaster. But all of a sudden, not a single disk is getting burned. The disks I am using are Ridata DVD+R. I thought they are good, because i have burnt more than 30disks from this set.
My dvd drive is Cyberhome DVDR/RW DX162D-A. I don't see there website anymore as I wanted to check if there is an updated Firmware. Please help. I am copying the LOG from the last time, intially the drive complained about an Empty disc (it had a new disc). I put the same disc back again, and then it started burning and after about 10% it failed. help please...
anybody has the this cyberhome drive?
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
(Nero Express)
Recorder: <DVDR/RW DX162D-A> Version: 170F - HA 1 TA 0 - 6.6.0.18
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <DVDR/RW DX162D-A >Version: 170F - HA 1 TA 0 - 6.6.0.18
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800BB-75FJA1 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : DVDR/RW DX162D-A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-252S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
DVDR/RW DX162D-A D: CDRom0
SAMSUNG CD-R/RW SW-252S E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 254MB (260096kB)
Free physical memory: 40MB (41392kB)
Memory in use : 84 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.12.2006
UDF/ISO compilation
2:30:50 PM #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
2:30:50 PM #2 Phase 114 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed (no file modified)
2:30:50 PM #3 Text 0 File Isodoc.cpp, Line 6359
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
2:30:50 PM #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
2:30:51 PM #5 Text 0 File Reader.cpp, Line 127
Reader running
2:30:51 PM #6 Text 0 File Writer.cpp, Line 122
Writer DVDR/RW DX162D-A running
2:30:51 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
2:30:51 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3309
2:30:51 PM #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
2:31:31 PM #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2083919 (463:05.44, 4070MB)
2:31:31 PM #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
2:31:31 PM #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: DVDR/RW DX162D-A, Media type: DVD+R
2:31:31 PM #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R DL.)
2:31:31 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2083920 (2083920) = #2083920/463:5.45
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2083920 blocks [DVDR/RW DX162D-A]
2:31:31 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [DVDR/RW DX162D-A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4267868160, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2083920 | lead-out | 1 | 0x41 | 0x00
2:31:32 PM #16 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
2:31:32 PM #17 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
2:31:32 PM #18 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
2:31:32 PM #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2.4x (3,324 KB/s)
2:31:32 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
2:31:32 PM #21 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x09CB0600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
2:31:32 PM #22 Text 0 File DVDR.cpp, Line 6168
Drive: DVDR/RW DX162D-A
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
2:31:32 PM #23 CDR -1207 File DVDR.cpp, Line 5306
Book Type automatically set to: DVD-ROM
2:31:32 PM #24 Text 0 File DVDPlusRW.cpp, Line 659
Start write address at LBA 0
DVD high compatibility mode: Yes
2:33:31 PM #25 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x092F0000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0x61 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
2:33:31 PM #26 CDR -1135 File Writer.cpp, Line 311
Write error
2:33:31 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
2:33:31 PM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
2:33:34 PM #29 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
2:33:34 PM #30 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
2:33:34 PM #31 Text 0 File DVDR.cpp, Line 6168
2:33:34 PM #32 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 1:07:32 PM
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.56a, size=17168 bytes, created 11/1/2004 2:02:55 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 11:59:42 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
That usually means a problem with the media or less possibly the burner. The media is cheaper and easier to adjust. DVD media can change by the batch, so even if it worked before, things change. I would try a different brand. If that doesn't help, there may be a problem with the burner.
What brand of DVD media are you using? Unless I missed it, the burner and Nero couldn't figure that out. If so, that's a bad sign.
I use Ridata/Ritek +R's all of the time with no problems....although I only use 8x Ridata/Ritek....the faster ones DO suck on my machine.
You have two options really....re-install Nero or stop using Nero and try another burning program. Prassi Ones is a 30 day free trial and ImgBurn is completely free. -
From tracking through posts through several sites :
http://www.dse.co.nz/cgi-bin/dse.filereader?45883789027564da2740c0a87f330716+EN/catalogs/SUPXH4140
Firmware: DVDR/RW DX162D-A , both 150F and 171F . -
Update to Nero 6.6.1.4, your version is old. Add another stick of ram, you are running with 40MB free which means a lot of extra unneeded disk activity.
You forgot to add that 40MB's free ram is enough also.Originally Posted by MysticE
Jerked images upon buring DVD
By Ilovm in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 11:28 -
Help a newbie out buring AVCHD.
By flyin-lowe in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2010, 12:47 -
Would really love help with buring videos to Dvds.
By Freakypenguin447 in forum Newbie / General discussionsReplies: 10Last Post: 9th Oct 2010, 21:16 -
MS Movie Maker and buring DVD
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 17:49 -
Buring video to DVD player
By BVG in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2009, 14:58
