Recently I have been trying to Cut/Rip my favorite scenes from DVD Movies in my collection.
I start by importing the DVD into re-author mode of DVD Shrink.
Secondly I Backup the selected clip and then re-open it in VideoReDo Plus
I then save it as a MPEG Program Stream (.mpg).
For some reason the files play perfect in Windows Media Player, and some don't play perfect in Winamp. But this isn't even the biggest issue. The biggest issue is when I import the video into Adobe Premeire, the video seems to STUTTER, the audio plays doesn't seem to lag as much but it also lags enough -- and the video clarity is basically the same as my actual DVD. But I really want to be able to edit using Premeire.
Can I anyone help me or give me suggestions as to why I can't seem to import these videos successfully into Adobe Premeire?
-Nikos
Premiere doesn't particularly like mpeg video. Like Vegas, it needs to uncompress the mpeg encoding in order to work with it. If you haven't allowed it time to do this, or you have a slower machine, this could cause performance issues when editing. You have not indicated which version of Premiere you are using (some are better at this than others) or what you PC specs are, so it is difficult to be more specific at this stage.
Read my blog here.
Is their another program similiar to Premeire that likes Mpeg?
I Have AP 6.0. My machine is reasonably fast. 3.6ghz and 1Gig of Ram. -
That is a very old version Premiere, and to handle mpeg I believe you would have to purchase and install the mainconcept mpeg editing plugin.
I believe Premiere Pro 1,5 or 2.0 will edit mpegs, but they are still not the best environment to do it. If you are going to edit mpeg files you are better off either converting to a lossless format while editing, or using an mpeg editor like VideoRedo, which you do already have.Read my blog here.
I only have the trial version of Video Redo, but is their a way to duplicate a portion of a scene and replay it back 3-4 times? In other words like the Premeire Timeline, to copy and paste a portion of a file 3 or 4 times, thus creating a new file with repeats? I have only used the program so far to CUT out scenes and convert the Shrink files into Windows Media Player playable files.
From your knowledge, does this program have that capability?
Problem with Sony Vegas importing DVDs
By aporreca in forum EditingReplies: 2Last Post: 31st May 2010, 09:28 -
Smoothness problem while importing avchd files
By effegieffe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 3rd Mar 2010, 21:55 -
Problem with importing from MiniDV to HDD. NTSC maybe ?
By antoinel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Sep 2008, 16:44 -
problem importing wav into EditStudio
By ecc in forum EditingReplies: 4Last Post: 20th May 2008, 14:41 -
Problem importing video into VirtualEdit
By acid_burn in forum EditingReplies: 3Last Post: 23rd May 2007, 10:07
