I'm new to encoding DIVX, so I hope I can get some help. I have several file sizes that I would like to encode so that they will either take up the entire width of the screen (widescreen movies/tv shows) or the entire screen (regular 4:3 sized tv episodes). The sizes are----
640x368, 640x352------these are obviously widescreen
576x432------these are the 4:3 tv episodes
What I'd like to know is how to scale these sizes up. Do I use a 16:9 ratio for the widescreen files and add 16 pixels to the width and 9 to the height for however big I need the files to be to keep the aspect ratio correct ? And in the same token, for the fullscreen files, do I add 4 pixels to the width and 3 pixels to the height to keep the ratio correct ? Thanks.
Results 1 to 1 of 1
Think about this. Once bread becomes toast, you can't make it back into bread.
Video sizing
By maryhigginsrice in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2011, 20:10 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
avi to mp4 video sizing
By rage777 in forum MacReplies: 7Last Post: 16th Feb 2008, 14:55 -
HD sizing for the net
By zoobie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 19th Aug 2007, 20:20 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
