i used bitlord to download a file (4GB) when i checked for the file in the input folder it was not there. i think it downloaded it some where else. is there a way to search the size of a folders? i checked my memory and it is still on my HD. does anyone here have any ideas how to find this missing file? i tryed to search the name but no luck![]()
You can search by size or when it was written. Or just look in Bitlord and the default location where it puts files should be listed. Most files are put somewhere in the Documents folders.
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 12:26 -
Need to find missing files that I converted using winavi
By azulbonita in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2008, 08:22 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 17:02 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 03:47 -
Missing Sensapi.dll File.....Need Some Help!
By RKelly in forum ComputerReplies: 2Last Post: 31st Jul 2007, 17:20
