@ BilboFett: No problem. I've learnt something new too, so everyone's a winner.
@ guns1inger: Nice work! Sadly, I've deleted the files I've authored so I can't give it a go (and emptied the Recycle Bin) but I may well do when I get a chance - just out of curiousity.
Results 61 to 66 of 66
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
So it seems a bug in DVD Lab Pro is artificially inserting a kind of 'layer break' pause at every chapter point when you make a chapter playlist?
I'll go one better than the instructions from the mediachance forums.
1. Open your DVD in PGCdit
2. Open the PGC that contains your sequence. The first PGC in the VTS is usually the entire sequence, with subsequent PGCs being the playlist sequence
3. Untick the flag under Layer Break ? for each cell
4. Look at the column marked Type Flags. If any cell does not have the values 8 0, click on it and untick every box except Seamless playback joint (8)
5. Repeat for each playlist
6. Save the results, burn and test
This still does not seem to solve the problem of disparate chapters still having a slight break, however it does make for a much cleaner and more consistent internal structureRead my blog here.
Originally Posted by BilboFett
I've stated my concern multiple times, but initially, I don't think anyone believed me...
I think the best way to simulate the seamless multi-story is by using "mixed angles." But because that is not available in DLP (which is what appears to be your software choice), then the next best thing would be to identify a scene where you could hide the jump. Have multiple assets, and join them by either using a Title Playlist, or connecting the end of the Main-Section to the appropriate "Ending Section" (condition splitter), or by using your own VM Commands. This would give you the flexibility to setup a "Scene Selection" Menu -- allowing you to jump directly to a certain chapter, and then playback flows accordingly.
NOTE 1: Maybe you can make a separate menu to allow the user to select between "Regular" or "Alternate Ending" playback. Or maybe during playback of either "Ending", you can add a Button-Over-Video (BOV) that will allow the viewer to manually switch to the "Other Ending"
NOTE 2: If you do setup a "Title Playlist" (in DLP it's just called "PLAY LIST" versus "Chapter Play List"), try adding a "dummy chapter" just before the very end of the "Main Section" This will be used when the user hits NEXT on their remote control, playback will jump to the "dummy chapter", then continue through the end of the "Main Section", and follow flow-control as you have defined it (if you do not have the "dummy chapter", then NEXT on the remote control "might" disrupt the flow control of your dvd).
Regards,
George -
I believe a "Mixed Angle" done properly for the switch between the two endings would be MUCH MORE seamless than a Chapter Playlist or a Title Playlist. The tricky part in this scenario is the added requirement for the different duration and different audio -- but that can be worked around in order to achieve the "seamless multi-story" effect.Originally Posted by guns1inger
One issue (imho) with the Chapter Playlist is that you cannot easily setup a "Scene Selection" menu (which might or might not be needed). Also, by setting up a chapter playlist in DLP, you have confirmed the "seamless joint" issue I mentioned earlier does exist, and that you must modify each sequential chapter using external tools (PGCedit) -- but after doing so, don't you start to see what looks like a regular "Title" with chapter marks along the way...
Regards,
George
Sync Subs Without Spoiling the Movie's Ending?
By Dogpoundz in forum SubtitleReplies: 9Last Post: 30th Nov 2011, 06:18 -
How do I make a still thumbnail image as a link to my movie.
By visualhippocracy in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2011, 18:59 -
Seamless Branching
By Mirkoschieder in forum MacReplies: 2Last Post: 6th Apr 2009, 11:58 -
Which Software for Seamless Branching?
By -horn- in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jul 2008, 12:15 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
