    Dec 2006
    I have a Sony duel deck dvd/vhs player recorder.When I try to record from vhs to dvd using a sony dvd-r or maxell dvd-r disc it starts recording normal but when I stop the recording it will not write to the dvd-r no title list appears and time left on disc is unchanged.The machine records fine to dvd-rw+rw no problem.Also my computer has failed to reconize the dvd-r saying no disc is in disc writer.What is the problem and is there a fix to it ,thanks in advance for any information.
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Make sure the video doesn't have Marcovision on it. Also check you media that you are recoding on. Most problem happen when you used inferior Media.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    Oct 2005
    666th portal
    sounds like the dvd-r wasn't finalized. there must be a way to finalize the disc in the sony, it won't be usable until it is.
