Just got the Philips DVP5960. I am having trouble playing avi files on a DVD+R.
I burned an avi file onto a DVD+R and named it "APNM1".
When I put the disc into the player the menu displays 35 files named "APNM1"
The movie starts to play fine but after about 10 minutes it stops. It seems as if the dvd player is breaking down the movie into chapters but is only playing the first chapter then stopping.
Am I doing something wrong? Anybody know how to fix this??
(I am using Roxio Drag to Disc to burn the avi file onto the DVD+R.)
Thanks to anyone who can help.
LIGUY
You can't use packet-writing software such as Roxio's Drag-to-Disc or Nero's InCD to burn your discs. They must be burned as a "data disc". Look around for that option in your Roxio. It's been several years since I used Roxio but it used to be there. I use Nero Express for burning data discs these days and it works very well.
And be sure to give your file a name like "APNM1.avi". I don't know if it would work without the extension.
Here's a couple of related threads you can check out:
https://forum.videohelp.com/viewtopic.php?t=317023
https://forum.videohelp.com/viewtopic.php?t=316369
Good luck.
AC3 .avi files trouble playing the sound in WINAMP
By NEVERMORE in forum AudioReplies: 0Last Post: 13th Sep 2010, 23:27 -
Trouble Playing or Editing Matrox HD AVI files past 10 minutes
By SCDVD in forum EditingReplies: 0Last Post: 29th Mar 2009, 13:07 -
philips 5992 firmware upgraded..avi files not playing which played before.
By phollow in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Dec 2008, 23:05 -
trouble playing .avi files
By starkythesparky in forum Software PlayingReplies: 5Last Post: 12th Jun 2008, 23:54 -
Philips DVP5960 and 1.4 gig avi
By dude112 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Dec 2007, 15:42
