wtf?
i installed a ati tv-tuner card and it screwed up my optical drives!
windows is not recognizing either the dvdrom nor the dvdrw!
its acting as if theyre not even there!
please help! any advice is appreciated
thanx
Do they still show in the BIOS screen? If so, try uninstalling the channels they are on in Device Manager, then reboot. That usually restores them. If that's a PCI card, try using a different PCI slot. The one under the AGP card is the worst to use as it shares IRQs.
thanx but the solution is here: (just figured it out 2 minutes ago)
http://support.microsoft.com/kb/894730 -
ok....actually at first i thought it did, but unfortunately it did not
i followed the instructions exactly and deleted the upper and lower filters.
then uninstalled the existing drivers drivers (in control panel) just like the instructions said to do.
however upon restarting the computer the drivers did not re-install like the instructions said that they would.
i tried manually installing the drivers (control panel / add hardware) but windows gives me this message:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing (code 39)"
help please. -
When installing these devices , your supposed to install the software package first , then shutdown and turn the pc off at power point ... install card (not in pci1 under agp ... NEVER) , and the system will pick it up from there .
However , ati are picky things ...
Pci2 / pci3 share resources and only one may have a card installed .
Pci4 / pci5 do the same ... only one can have a crad installed .
You may find you need to remove other cards , so as to find the pci slot the device works correctly
Under xp , as you dont have sp2 installed , you may require
http://www.microsoft.com/downloads/details.aspx?familyid=8DFD1B6D-E177-4A0E-91D0-B4310...displaylang=en
Ms release a midi security patch that caused issues for capture devices .
What Does 5.25" x 1/2 H Mean In Optical Drives/Burners?
By rckowal in forum DVD & Blu-ray WritersReplies: 10Last Post: 25th Jan 2011, 03:36 -
Data has dissapeared from my PC, for no Reason, how do i restore it?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2008, 22:40 -
SATA Optical Drives on NVIDIA GeForce 7050/610I Chipset
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 19th Jun 2008, 17:52 -
Optical drives don't record.
By Vrex in forum Software PlayingReplies: 5Last Post: 28th Mar 2008, 11:17 -
Repairing Registry- Incomplete or damaged info ?? No Optical Drives!!!
By Noahtuck in forum ComputerReplies: 11Last Post: 28th Dec 2007, 23:42
