this wasn't a problem with ( PC ) but i've converted to ( MAC ) and learning and yes i read but the listings are still confusing?
i'm tring to convert an AVI file to a dvd format using ffmpegx but still lost?
1. loaded the avi file but which conversion format do i pick ?
a.dvd lo
b.dvd mpeg2enc
c. dvd ffmpeg
d. mpeg-ts
is there a prg that just gives me a video/audio ts file that i can burn to a dvd disc?
a. dvd lo -- convert your source file to DVD-Video using the mpeg2enc engine, at half the horizontal resolution, allowing more minutes per disc.
b. dvd mpeg2enc -- convert your source file to DVD-Video using the mpeg2enc engine, good options available.
c. dvd ffmpeg -- convert your source file to DVD-Video using the ffmpeg engine, quite fast, no built-in 3:2 pulldown available tho'.
d. mpeg-ts -- creates a transport stream file using the ffmpeg engine. Not very suitable for DVD.
e. KDVD -- convert your source file to DVD-Video using the mpeg2enc engine, with low bitrate optimized KVCD parameters, allowing more minutes per disc.
thanks for rhe reply!
ok this is where i'm at;
1st i joined 2 avi files under the TOOLS option - task was sucessfull
2nd i then loaded that avi file into theSOURCE FORMAT section
3rd under the TARGET FORMAT i chose DVD MPEG2ENC
4th under AUDIO tab i chose AC3 ( dolby digital)
its starts to encode then gives shows FAILED
i also tried using Toast, it burned the file ok but without any audio????
any i doing something wrong??????
Lost with Premiere Elements 10 & Canon Vixia M41
By skyfranks in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2012, 22:16 -
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 02:25 -
New to ffmpegX... Lost...
By Germaris in forum ffmpegX general discussionReplies: 3Last Post: 16th Apr 2009, 16:30 -
ffmpegX 0.0.9y & future?
By Flarch in forum ffmpegX general discussionReplies: 12Last Post: 11th Apr 2009, 17:56 -
ffmpegX jumps to "finished" crashes computer, lost progress.app
By jegler in forum ffmpegX general discussionReplies: 16Last Post: 2nd Jun 2008, 19:53
