I have the same problem as: https://forum.videohelp.com/viewtopic.php?p=1602592 (read it).
There's just a tiny difference: my files are AVI, and not VOB. Is it the same procedure?
For avi you can use virtualdub. Load the file and go to File-save wav. It will extract the audio to wav and you can convert to anything you want. Or you can go to "audio" tab and select wav to add a wav track.
For other formats or if it is a vob file use virtualdub mod or virtualdubmpeg2 - then you would use "streams" tab and choose stream list to extract the audio if its not wav.
You can use gspot to determine the audio format - most likely its a mp3 format that can easily be converted to and from wav with a program like audacity.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 06:31 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
merge avi with double sound track
By facan in forum ffmpegX general discussionReplies: 11Last Post: 22nd Jun 2008, 16:29 -
Converting AVI file with separate subtitle track
By dgarmaise in forum ffmpegX general discussionReplies: 2Last Post: 7th Jun 2008, 08:08 -
Adding new audio track to avi file
By skaleton in forum AudioReplies: 5Last Post: 11th Apr 2008, 13:29
