I use dvd shrink 3.2 and dvd decryptor. over the last month or so, almost all the dvd's I try to burn have given me some kind of error. I'm not talking about HD DVD's or anything like that. am I missing something? I haven't had any trouble burning dvds before. Is there some kind of new encryption on them?
Results 1 to 10 of 10
If by "burn" dvd's you mean "rip" dvd's try ripit4me or dvdfab decrypter to rip with. They can handle most of the newer protection schemes that prevent you from backing up your dvd's.
Yep a second for ripit4me or dvdfabdecrypter. Both are updated frequently - dvd shrink and dvd decrypter are no longer updated.
Basically you have to rip it to your hard drive first and then open the folder with dvd shrink.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I'm having the same problems I think as the OP. I can rip the DVD's just fine using the programs mentioned above, but when I go to actually burn them to disk using DVD Decrypter I will get a message saying invalid format or something similar. Everything else in the process works just fine.
Never had this show up till very recently. -
As long as you are ripping with the latest updated tools, you should be having no trouble.
Google is your Friend -
The movie Over The Hedge gives me that error message as does Monster House. I just tried another movie and it worked fine. I'm using DVDFab Decrypter to rip it and then DVD Shrink and finally ImgBurn to burn it to disc.
@ mz32quick - try using ripit4me on over the hedge. Also make sure you have the latest version of dvdfab decrypter - I don't know how frequently it is updated.
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 17:46 -
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 15:57 -
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
Trouble converting MKV to DVD and burning....
By DVDNewb in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2007, 00:14 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 03:23
