    Muscle Shoals, Alabama
    I want to create a DVD from a VHS of a football game. I have the Dazzle Hollywood DV-Bridge to convert the video to AVI on my system. What are the settings to encode this for best quality? I have a few options: Ulead's DVDMovieFactory, MyDVD, or TMPGEnc. Which one do you guys suggest and at what settings would get me the best quality? If I have to create on two DVD's, that is OK. I just want to get some very good quality.
    Thanks!!!!
    700Mhz, 128 SDRAM, 10GB disk for OS and 60GB disk for video, Windows 98SE.
    _________________
    Eric Hill
    President
    J & E Designs, Inc.
    hille@wlv.com
    <font size=-1>[ This Message was edited by: ehill on 2002-01-16 07:14:23 ]</font>
    Anyone?
  3. Not familiar with Dazzle, but after that:
    I believe that if you encode (using TMPGenc) for Ulead movie factory you must use 720x480, BR x-9600, sound at 48000, BR 96-384, aspect ratio 4:3. I'm inclined to max the motion search setting, but I think the faq recs using High.
    not familiar with MyDVD, but that's not boosted much around here as far as I can tell.
    it'll be a pokey encode on your system, but hey, it's forever.
    oh
    Thanks. That helps. I will let you know how it goes.
    Eric
