i have several part finished dvd which i would like to put onto 1 or more discs, but when i use the software i have i get" insert an empty disc" when means only 1 dvd on 1 disc, any one know software where i can add more then 1 subject to a dvd, ive tried sonic mydvd and it wasnt very sucessful. IM NEW TO THIS SORT OF THING
DVD Video does not support multi-sessions. All DVD Video discs must be written as a single session. Most divx/Xvid capable players will not read multi-session discs either.
You need to either
1. Finish your projects properly so you have a full DVD ready to burn
or
2. Use DVD Shrink in re-author mode or TDA's Add Video option to merge all your part finished projects into a single DVD. Note : you must compile a full DVD structure for all of these little projects before either of these will open them. DVD Shrink in re-author mode will lose you any menus you have made.Read my blog here.
https://forum.videohelp.com/viewtopic.php?t=270121
Guide use's six titles and only freeware .
Dvdshrink should only be used if the complete project dosent quite fit 4.3gig on dvd-r .
Burn with imgburn
Works perfect ... compared to some tool's ... tda , and dlp contain bug's .
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01 -
DVD shrink fails to rip home recorded dvd in multiple sessions
By sybariten in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 21:42 -
DVD Multi-sessions - How to Do?
By markannab in forum Authoring (DVD)Replies: 20Last Post: 19th Jul 2007, 20:03
