    Dec 2006
    Hong Kong
    If i want to open the Divx player,it will to this
    USA
    Well, that's apparently an error, though I'm not sure which one.
    For the present, I would just try a different player. There are a lot out there that play Divx. And they may be better than Divx's own player.
    First, I would try VLC Media Player. It has it's own codecs and it can play most anything and it's freeware. Another that is popular is Media Player Classic. It may need the Divx or Xivid codec. Also freeware.
    And you may be able to go to the Divx homepage and trace down that number for the error and see what it says. My first guess is that you have another codec installed that is interfering with the player. Have you installed anything recently? Codec packs especially can cause problems.
    And welcome to our forums.
    Dec 2006
    Hong Kong
    but now what the problems in my computer??
    i can open this software in the before,i don;t know why can't open in now
