Hi All, Been a long time user and LOVE IT!!! I have a small problem with a new iMac G5.
I installed v.9x.r2 and the binaries and when I try to view a file using the "info" button or view it in mplayer neither respond. It will encode the file!!! I have ver9.w on my iBook g3 and the files play on mplayer and the info is available.
Also I tried to fix the .avi file and it said:
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
AltiVec found
CPU: PowerPC
File not found: '/Volumes/xxxx
Exiting...
Failed to open /Volumes/xxxx
Cannot open file/device.
Yes, I booted from a second partition and I used the browse option to locate the file.
The main start-up HD also has ver. x.r2 and has the same problems....
Please help...it's alot nice towatch on a 24" screen as opposed to 14....
Try downloading and installing the binaries again. If mplayer is missing or corrupt, then a fresh copy could fix that.Originally Posted by glynnkjk
As you've x'ed out the path and file, it is not clear if it tries to find your video file or a program component, or if there is a problem with the path itself.Originally Posted by glynnkjk
You should run ffmpegX from the same partition as you booted from.Originally Posted by glynnkjk
Forward and rewind functions are choppy in H264 video, please help
By ejai in forum Video ConversionReplies: 4Last Post: 24th Aug 2011, 15:54 -
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 12:40 -
Two Different Concert In One DVD with menus, chapters, play all Functions.
By madman1987 in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 20:17 -
Do I need a remote control to program TBC/3R etc functions in JVC HR-S7955?
By leon43 in forum RestorationReplies: 1Last Post: 14th Dec 2008, 08:04 -
How Customize Menu Navigation in order to let the remote perform functions?
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2007, 10:33
