Here's the familiar error:
**ERROR: [mplex] File /Volumes/externaldrive/Clip.ff.mpg unrecogniseable!
Here's the precise ffmpeg command that results in the file that mplex can't recognize (mplex can recognize and mux the source file, Clip.mpv):
/Applications/ffmpegX.app//Contents/Resources/ffmpeg -r 59.96 -i /Volumes/externaldrive/Clip.mpv -y -threads 2 -map 0.0:0.0 -target ntsc-dvd -b 9000 -aspect 16:9 -s 720x480 -r ntsc -g 32 -me epzs -qmin 1 -qmax 5 -an -benchmark /Volumes/externaldrive/Clip.ff.mpg
Here's the mplex command that generates the error:
/Applications/ffmpegX.app/Contents/Resources/mplex -f 3 -o /Volumes/externaldrive/Clip.mpg /Volumes/externaldrive/Clip.ff.mpg /Volumes/externaldrive/Clip.ac3
Changing the name extension of the input video file for the mplex command to ".mpv" doesn't help.
Can the ffmpeg command be modified to transcode a video elementary stream so that it can later be muxed using the mux button in the tools segment tab of ffmpegX? (I don't think ffmpegX can be used to transcode the original .mpv file because there doesn't seem to be a way to make ffmpegX distinguish between input and output frame rates. If there is, please tell me that, too!)
Thanks.
Results 1 to 1 of 1
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
Impression DVD Pro Problem "Mux: invalid video error&qu
By Kippo in forum Authoring (DVD)Replies: 1Last Post: 24th Sep 2008, 12:47 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
