Hi,
now and then I add extra subtitles to some movie dvds, subtitles that I get in text format and change to images.
First I demux the dvd and then, in order to see if the subtitles are synchronized, I have to mux the video and audio streams and check the sync with vobsub or subtitle workshop.
It would be good to spare that last step and be able to check the sync without having to mux. I'm wondering if there's a way to do thatt.
Thanks in advance.
Some subtitle editors will allow you to open the video and audio streams used for DVD authoring, there you can sync your subtitles before rendering them for the final DVD authoring steps. Try Aegisub, for example. Otherwise, you can always generate .avi and .wav files and use them instead to check that the sync is OK.
i have a video that has 2 audio streams..what does that mean?
By vincy in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 05:45 -
What's a Good Rig for Live Broadcasting of Video/Audio Streams
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2010, 17:42 -
Use to author from separate audio and video streams?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 05:41 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00
