  1. I downloaded Ali from the IRC groups.
    Disk one assembled, converted and burned fine.
    Now there is disk 2
    I used both WinRar and WinAce to assemble
    I had to use VcdGear 2.0 to convert to an MPEG VcdGear 3.06 would not work.
    When I tried to burn a Video-CD with Nero I get this prompt.
    The file Ali 2.mpg is invalid,need MPEG-1 which was encoded for Video-CD:
    audio: 44.1kHz; stereo; 224kBit/s
    video: 352x240/29.97Hz or 352x240/23.976Hz or 352x288/25Hz
    The following problems were found:
    -stream encoding which is invalid for a [Super] Video-CD
    -no video
    Does anyone have any suggestions for what I can do to correct this problem? I would like to fix this after all the work it took to download all these parts!
  2. Did the S/VCD image come in the CUE/BIN image format? If it did, don't convert it, just burn it!
    http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
    http://www.vcdimager.org/guides/burning_cuebin_images.html (mirror)
    Regards.
    Michael Tam
    w: Morsels of Evidence
